Moussa854
Nov 21, 2018Aspirant
Block adult and peer to peer on WAC510
I have an access point that is functioning as a router and AP and would like to block adult and peer to peer sharing websites. OpenDNS did not work.
- Anyone had luck doing so?
Best
Moussa854
Nov 23, 2018Aspirant
I was going to try the web interface again but had issues with my computer. I will fix my computer and post teh result here.
RaghuHR
Nov 29, 2018NETGEAR Expert
Please refer the attached write-up and config details. Share your feedback once follow the procedures.
Thanks,
Raghu
- Moussa854Nov 29, 2018Aspirant
I confirm this worked using "208.67.222.123" and "208.67.220.123"
I had to reset the AP and start fresh as I made several changes.
Thank you all.
Best,
Moussa
