Eagle04
Jun 19, 2024Aspirant
Bug: Neighbor AP Known List not Populating
I have several WAX620, WAX610, and WAX610Y's across two different sites, all running in local management mode. Since version 10.8.6.3, if I look under Configuration -> Security -> Neighbor AP -> Kno...
Eagle04
Jun 20, 2024Aspirant
Thank you for the quick response. Again, outside of the display issue, it appears that the Neighbor AP functionality is still functioning and assisting with roaming between APs when on WPA2. However, I assume your team will be able to confirm that in the code. Thanks again.
schumaku
Jun 20, 2024Guru - Experienced User
Yes it does. Roaming WP2-PSK is comparably simple, it does not even require any cloud controller support like WPA3-SAE for example.
- scoobydoo73Nov 02, 2024Aspirant
Even with the latest firmware 10.8.10.10 the Neighbor AP feature is partially broken. It only shows a subset of surrounding 2.4 GHz networks and now all of a sudden it includes some in my own clients, which are not APs.
Absolutely nothing is found in the 5 GHz spectrum. This used to work just fine in older firmware versions such as 10.6.1.2.
- PramendraNov 05, 2024NETGEAR Expert
Hi scoobydoo73 ,
Request you to please share the latest logs from the AP. I will DM my business email to you.
Warm Regards
Pramendra Singh
NETGEAR NFB Wireless- scoobydoo73Nov 12, 2024Aspirant
Hi Pramendra,
Thank you for reaching out.
After a few days the Neighbor AP feature miraculously started picking up Wifi signals and is not working as expected.
Thanks again.
