jameslast's avatar
jameslast
Business-Central / WNAP210v2: mac filtering
Hello All,   searched the console and downloaded a manual but I cannot find this one thing: Is it possible to enable mac filtering in business central?   Many Thanks.   Greetings, J.
  • ericl's avatar
    ericl
    Nov 02, 2016
    Hi J.
    After configuring the portal, the vouchers menu is on the right tab on the SSID created for the guest account.
    Page 138 from the manual is handling "Manage Vouchers With a Clerk User Account" and gives a step by step procedure to create the vouchers.
    When you have created the voucher you see the voucher in a list. I suggest to use the name of the person as a holder for the voucher. So you have a proper overview.
    There is no way to add a batch of users. But you are able to activate and deactivate the ticket.
    Guest logon: When the user select the SSID, he only have to enter the password and then he is able to use the network
    I hope this will help.
    Eric
ProSupport for Business
