ebenus_it
Mar 31, 2023Follower
Can we merge Netgear WAX610 Access Point and UniFi UAP-AC-Pro
Hello everyone, I want to know if is it possible to merge all my execting access points in one SSID (Netgear WAX610 5No's & UniFi UAP-AC-Pro 8No's) if possible please let me know how we can do i...
michaelkenward
Apr 01, 2023Guru - Experienced User
What are these? Google isn't much help.
You can give WiFi sources whatever SSID and password you like, whether they will play nicely together is another matter.
If you want to flood the place with a seamless SSID that WiFi clients can move between without interruption as they move from source to sources, you need Mesh WiFi technology. As yet different brands of WiFi source don't work together in a Mesh network.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your question.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
