jazzaus_tts's avatar
May 06, 2022
Can't connect to ORBI channel sometimes
We are in a small office with the SRR60 and a single SRS60. Firmware V2.7.0.122.
Everything configured and working for over a year. No recent changes other than firmware updates when available.
4 channels: Admin, Main employee access channel, IOT channel and a guest channel.
One day a user couldn't connect to main channel. Left the office, came back to the office the next day and could connect.
I am the admin. I had the same experience the next time I was at the office that I couldn't connect to the main channel. I then tried connecting to the Admin channel and got connected. I then disconnected from the Admin channel and connected to the main channel without an issue.
Other users come and go and have yet to have a connection issue.
I don't see anything in the logs about rejected connections.
I have done a reboot from the ORBI web interface.
I would rather not do a factory reset and then have to reconfigure.
Anyone else have a similar situation lately?
Joel
  • plemans's avatar
    Are you on iOS (and the coworker with the issue)?
    Are you using random ip/mac address?
    or icloud relay?
    • jazzaus_tts's avatar
      jazzaus_tts
      Tutor
      The laptops in question are Windows 10.
      No iOS or Android devices seem to be having the problem.
      I am using dynamic ip addressing with the ORBI performing DHCP tasks for LAN assignment.
      For internet ip address the ip is dhcp as well from our provider.
      • plemans's avatar
        what modem/gateway is the orbi connected to?
ProSupport for Business
