Decenenti
Feb 17, 2017Aspirant
Can't Factory Reset WC7520
I m trying to factory reset a ProSafe WC7520 controller so we can get access (unknown username and password) however am having no luck. I have tried the instructions here: http://kb.netgear.com/6...
- Feb 21, 2017
Hi,
Before raising a support case, Can you press and hold the reset button for more than 10seconds, and until the power LED starts blinkiing. On the consoloe you should be able to see the following message
"FACTORY DEFAULT APP: Reset to default requested, system will be restarted shortly !"
Decenenti
Feb 20, 2017Aspirant
Ok thanks, I will open a support case.
LaxmankumarG
Feb 21, 2017NETGEAR Expert
Hi,
- DecenentiFeb 23, 2017Aspirant
LaxmankumarG wrote:Hi,
Perfect, that resolved the issue, thank you!
- Nov 23, 2018Retired_Member
