pedroespo
Mar 27, 2023Follower
Compatible PoE Wireless Access Points for WAX202 acting as router
My current setup is a WAX202 (WAX202-100NAS) AP set up as a router. The other half side of my house has weak signal, I would like to purchase an access point that is strictly PoE so I can do a networ...
- Mar 28, 2023
WAX214v2, WAX218, WAX220 all will be good match for WAX202 acting a router.
ErwinL
Mar 28, 2023NETGEAR Moderator
Hello pedroespo,
And welcome to the NETGEAR Community! 🙂
Do you plan to set bridging where you will set the POE access point to get wifi signal from WAX202 and then have wired connections of devices to the access point on the other end?
Have a lovely day,
Logan
Netgear Team
nmhTester
Mar 28, 2023NETGEAR Employee Retired
- schumakuMar 29, 2023Guru - Experienced User
Glad to read from you here nmhTester !
Does this new WAX214v2 support - different from the current WAX214 and WAX218 releases - a bigger selection of 80 MHz channels? With the limited 5 GHz channel availability, deploying the models suggested (either multiple, or along other AP and routers) is very difficult due to obvious interferences called - lack of options to have dedicated 5 GHz coverage on air.
Needless to repeat it again: The current limited selection of VT80 channels (read: just one set!) is not acceptable - no alternate channels, no DFS, ...
TIA
-Kurt
- vikumarApr 03, 2023Tutor
Hi pedroespo
Please find the WAX220 features, it may help in finding correct AP for your setup.
WAX220 FEATURES:
- Wi-Fi 6 (802.11ax) capable
- Dual band: 2x2 2.4 GHz radio, 3x3 5GHz radio
- Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4GHz band and 3600 Mbps on 5GHz bands
- Supports till 160MHz channel width.
- PoE+(802.3at) powered
- 2.5Gbps Ethernet Link
- Support MU-MIMO function on both 2.4GHz and 5GHz radio.
- 128 concurrent client connections (64 clients per radio)
- 4 SSID support
- WPA3 authentication support
Thanks,
Basavaraj
- schumakuApr 04, 2023Guru - Experienced User
To compare with the existing router, here the WAX214 v2.
WAX214 v2 Features
- Dual band: 2x2 2.4 GHz radio, 2x2 5GHz radio
- Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4 GHz band and 1200 Mbps on 5 GHz bands
- Supports a channel width of up 80 MHz on the 5 GHz band.
- PoE+ (802.3at) powered
- 1 Gbps Ethernet Link
- Supports MU-MIMO on both the 2.4 GHz radio and 5 GHz radio.
- 4 SSIDs supported
