pedroespo
Mar 27, 2023Follower
Compatible PoE Wireless Access Points for WAX202 acting as router
My current setup is a WAX202 (WAX202-100NAS) AP set up as a router. The other half side of my house has weak signal, I would like to purchase an access point that is strictly PoE so I can do a networ...
- Mar 28, 2023
WAX214v2, WAX218, WAX220 all will be good match for WAX202 acting a router.
nmhTester
Mar 28, 2023NETGEAR Employee Retired
schumaku
Mar 29, 2023Guru - Experienced User
Glad to read from you here nmhTester !
Does this new WAX214v2 support - different from the current WAX214 and WAX218 releases - a bigger selection of 80 MHz channels? With the limited 5 GHz channel availability, deploying the models suggested (either multiple, or along other AP and routers) is very difficult due to obvious interferences called - lack of options to have dedicated 5 GHz coverage on air.
Needless to repeat it again: The current limited selection of VT80 channels (read: just one set!) is not acceptable - no alternate channels, no DFS, ...
TIA
-Kurt
- vikumarApr 03, 2023Tutor
Hi pedroespo
Please find the WAX220 features, it may help in finding correct AP for your setup.
WAX220 FEATURES:
- Wi-Fi 6 (802.11ax) capable
- Dual band: 2x2 2.4 GHz radio, 3x3 5GHz radio
- Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4GHz band and 3600 Mbps on 5GHz bands
- Supports till 160MHz channel width.
- PoE+(802.3at) powered
- 2.5Gbps Ethernet Link
- Support MU-MIMO function on both 2.4GHz and 5GHz radio.
- 128 concurrent client connections (64 clients per radio)
- 4 SSID support
- WPA3 authentication support
Thanks,
Basavaraj
- schumakuApr 04, 2023Guru - Experienced User
To compare with the existing router, here the WAX214 v2.
WAX214 v2 Features
- Dual band: 2x2 2.4 GHz radio, 2x2 5GHz radio
- Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4 GHz band and 1200 Mbps on 5 GHz bands
- Supports a channel width of up 80 MHz on the 5 GHz band.
- PoE+ (802.3at) powered
- 1 Gbps Ethernet Link
- Supports MU-MIMO on both the 2.4 GHz radio and 5 GHz radio.
- 4 SSIDs supported
