pedroespo
Mar 27, 2023Follower
Compatible PoE Wireless Access Points for WAX202 acting as router
My current setup is a WAX202 (WAX202-100NAS) AP set up as a router. The other half side of my house has weak signal, I would like to purchase an access point that is strictly PoE so I can do a networ...
- Mar 28, 2023
WAX214v2, WAX218, WAX220 all will be good match for WAX202 acting a router.
vikumar
Apr 04, 2023Tutor
Hi pedroespo
Please find the WAX220 features, it may help in finding correct AP for your setup.
WAX220 FEATURES:
- Wi-Fi 6 (802.11ax) capable
- Dual band: 2x2 2.4 GHz radio, 3x3 5GHz radio
- Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4GHz band and 3600 Mbps on 5GHz bands
- Supports till 160MHz channel width.
- PoE+(802.3at) powered
- 2.5Gbps Ethernet Link
- Support MU-MIMO function on both 2.4GHz and 5GHz radio.
- 128 concurrent client connections (64 clients per radio)
- 4 SSID support
- WPA3 authentication support
Thanks,
Basavaraj
schumaku
Apr 04, 2023Guru - Experienced User
To compare with the existing router, here the WAX214 v2.
WAX214 v2 Features
- Dual band: 2x2 2.4 GHz radio, 2x2 5GHz radio
- Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4 GHz band and 1200 Mbps on 5 GHz bands
- Supports a channel width of up 80 MHz on the 5 GHz band.
- PoE+ (802.3at) powered
- 1 Gbps Ethernet Link
- Supports MU-MIMO on both the 2.4 GHz radio and 5 GHz radio.
- 4 SSIDs supported
