tday0969
Apr 10, 2022Aspirant
Connecing a WAC510 to a Nighthawk Mesh System
I'm trying to set up a new access point on my cousin's network. Her old Accepoint died. I was going to replace it with a WAC510. Her office is away from the main house and is connect via a wireles...
schumaku
Apr 11, 2022Guru - Experienced User
The Ethernet port you try to connect the WAC510 is on a wiröews extender system, somehow coupled to a Nighthawk Mesh system serving the main building.
Simple test would be connecting another computer with a wired adapter to that Ethernet port to confirm this is workable.
Have connected the WAC510 using the WAN port to this unknown extender?
The fine documentation https://www.downloads.netgear.com/files/GDC/WAC510/WAC510_UM_EN.pdf says for Power LED remains solid amber on p.233 on Diagnostics and Troubleshooting
When you turn on the power to the access point, the Power LED lights solid amber
temporarily and then turns solid green, indicating that the startup procedure is complete
and the access point is ready.
If the Power LED remains solid amber and does not turn solid green, a failure occurred
or the access point is malfunctioning.
If the Power LED does not turn solid green, do the following:
1. Turn the power off and back on and wait several minutes to see if the access point
recovers.
2. If the access point does not recover, you can use the Reset button to return the
access point to its factory default settings. For more information, see Use the Reset
button to reset the access point on page 196.
If the error persists, a hardware problem might exist. For recovery instructions or help
with a hardware problem, contact technical support at netgear.com/support.
recovers.
tday0969
Apr 11, 2022Aspirant
I am just connecting directly to the router. The bridge is not in play until I get the Access Point communicating with the network.
When I connect to my home network the Access Point work just fine.
When i connect to the nighthawk, it does not get to the green stage.
All thing being equal it should work on both if directly connected. I suspect that there is something in the nighthawk that is preventing it from becoming active but I don't know what.
- plemansApr 11, 2022Guru - Experienced User
What mesh system is it? (mk60? mk80?)
What modem/gateway is the mesh system connected to?
Why not try factory resetting the access point and connecting it to the nighthawk system and running setup? just seems like it could be something that you're doing when setting it up on your system that its causing a bad setting/issue.
