azizrj's avatar
azizrj
connecting 3 WAC720 using wc7500
I have (new setup and new netgear family)   three VLANs 10,20 and 30 configured on M4100 switch and I have  wc7500 in play and all behind a sonic wall. The three SSIDs wouldn't not  work if the thre...
  • DaneA's avatar
    DaneA
    Feb 13, 2017
    azizrj,
    Thanks for the update.  I'm glad to know that the APs are working fine. :)
    Since the APs are working fine and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
