azizrj
Jan 28, 2017Aspirant
connecting 3 WAC720 using wc7500
I have (new setup and new netgear family) three VLANs 10,20 and 30 configured on M4100 switch and I have wc7500 in play and all behind a sonic wall. The three SSIDs wouldn't not work if the thre...
- Feb 13, 2017
Thanks for the update. I'm glad to know that the APs are working fine. :)
Since the APs are working fine and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
azizrj
Feb 12, 2017Aspirant
Hi,
sorry for late reply, I was out of order for awhile.
It seams to be working fine. I had two APs very colse to each other like 10 feet. I disconnected one. It seams to be working fine so far. I'll need to move one of them about maybe 30 to 50 feets away from the other one. I have two working fine. I am still learing netgear where I like very much.
Thanks, Aziz
DaneA
Feb 13, 2017NETGEAR Employee Retired
DaneA
