EastsideDev
Apr 09, 2018Aspirant
Connecting two WAC510 to the same network
My network configuration: - Cable modem Can I have one WAC510, connected to the cable modem, with the WAC510 set up as a router (DHCP), and the output from this WWAC510, going into my PoE swi...
- Retired_MemberApr 09, 2018
Hi EastsideDev,
Welcome to Netgear Community.
The simple network setup with WAC510 you are looking for should work(Refer image attached). With same wireless configuration on both WAC510, You can move between APs. Please let us know if you face any issues.
There could be bottle necks if you setup complex wireless networks. Please share how exactly you want to setup wireless networks(configurations), So that we can help more on that.
Thanks.
Sharan
Retired_Member
Apr 09, 2018Hi EastsideDev,
Thanks.
Sharan
- Retired_MemberApr 16, 2018
Hi EastsideDev,
I just want to follow-up on this. We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Thanks.
Sharan
