MuTak's avatar
MuTak
Follower
Dec 14, 2022
Disable SSLv2 and SSLv3 for WAC720
Hi, I am using a WAC720, wireless router. I would like to disable SSlv2 and SSlv3 due to vulnerabilities, is it possible to configure? Is it possible without replacing it with a new model?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Anything you can configure should be described in the manual.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
ProSupport for Business
