mhndsh
Mar 25, 2018Aspirant
Disable WG103 Rogue AP is better?
Hi, Is it better for AP performance to disable Rogue AP feature if i'm not using it? Thanks
- Mar 27, 2018
Hi mhndsh,
As far as I have checked, the performance of the WG103 is not affected even if the Rogue AP Detection is turned on. It would be best to turn on Rogue AP Detection because unknown APs and wireless stations are prevented from connecting to the WG103.
Kindly read pages 4-19 to 4-20 of the WG103 reference manual here about Rogue AP Detection.
DaneA
NETGEAR Community Team
DaneA
Apr 01, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
