jeffsoltor
Aug 08, 2018Aspirant
WMS5136 can't discovery WG103 or WNDAP350
I cannot discovery any of my access points after upgrading the firware in my WMS5316 to v2.1.7. My access points are as follows:
WG103 firmware v2.2.5
WNDAP350 firware v3.7.9.0
I have tried auto discovery, IP range (everything on same subnet). I've reset the WMS5316 to factory defualts and tried discovery again without success. I can ping every access point from the WMS5316 using Diagnostic--->Ping (--- 192.168.0.144 ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9023ms rtt min/avg/max/mdev = 0.271/2.537/19.417/5.718 ms).
I've read several articles, but most are suggesting using the latest firmware for my hadware, which I have, but nothing seems to work.
Small business network (server 2008R2) with with Netgear GS728TP switches
I checked a number of times, and yes, SNMP is enabled in all the WG103s
- jeffsoltorAspirant
Yes, all my APs are on the same network as the WMS5316. My WMS5316 could discover all my APs before upgrading to firmware v2.1.7. I have even tried downgrading to v2.1.5, but still cannot discover APs.
- LaxmankumarGNETGEAR Expert
Hi,
Can you make sure the firmware in WMS5316 is 2.1.7
and WNDAP350 is 3.7.9.0
1. Login to the WNDAP350 and Disable the cloud mode.
2. Login to the WNDAP350 and enable the SNMP.
after discover the AP, it should work fine.
