jeffsoltor
Aug 08, 2018Aspirant
WMS5136 can't discovery WG103 or WNDAP350
I cannot discovery any of my access points after upgrading the firware in my WMS5316 to v2.1.7. My access points are as follows:
WG103 firmware v2.2.5
WNDAP350 firware v3.7.9.0
I have tried...
- Sep 04, 2018
I checked a number of times, and yes, SNMP is enabled in all the WG103s
JohnC_V
Aug 09, 2018NETGEAR Employee Retired
Hi jeffsoltor,
As per checking, I found out that the firmware of your APs is suitable for the latest firmware of the WMS5316.
Have you checked if the IP address of the APs are on the same network with the WMS5316?
Here is the reference.
- jeffsoltorAug 09, 2018Aspirant
Yes, all my APs are on the same network as the WMS5316. My WMS5316 could discover all my APs before upgrading to firmware v2.1.7. I have even tried downgrading to v2.1.5, but still cannot discover APs.
- LaxmankumarGAug 13, 2018NETGEAR Expert
Hi,
Can you make sure the firmware in WMS5316 is 2.1.7
and WNDAP350 is 3.7.9.0
1. Login to the WNDAP350 and Disable the cloud mode.
2. Login to the WNDAP350 and enable the SNMP.
after discover the AP, it should work fine.
Hi,
Please follow the guidelines provided in the document attached, which will help you to discover and manage the APs.
