deviat's avatar
deviat
Dynamic VLAN on wax
Just picked up a WAX620, spun up Insight, and am pretty stuck on how to configure Dynamic VLANs, or add the additional tagged vlans to the single port.
None of the documented help links in Insight function so kinda at a loss.
https://kb.netgear.com/000061875/How-do-I-enable-dynamic-VLAN-assignment-on-my-access-point
For example, aboe... might be pretty helpful... but link no work.
Any help or guidance is high appreciated it, currently using Freeradius, and connected AP to a Cradlepoint E3000 router with the configured VLANs and Access/Trunk port.
  • hnagaraju's avatar
    hnagaraju
    NETGEAR Employee Retired
    Dynamic VLAN is per SSID configuration.
    If you have Insight management enabled. you can enable Dynamic VLAN at the SSID configuration.
    Step 1) Go to location configuration and set up the RADIUS server
    Step 2) Go to wireless settings and enable Dynamic VLAN.
    To make it actually work,
    Please make sure the ethernet port where the AP is connected is a TRUNK and allows all VLAN on which the client joins.
    • deviat's avatar
      deviat
      That it is. Is there a specific list or expected attributes the WAX620 is expecting in the access-accept?
ProSupport for Business
