Retired_Member
Nov 23, 2018Facebook Authenication - WC7520
Is there anyway to use a captive portal on Facebook with the WC7520.
Hi Retired_Member,
The WC7520 does not support Facebook Authentication via its Captive Portal.
I recommend you either the WC7600v2 or WC9500 wireless controller. There is an option to indicate a Redirect URL when setting up a Captive Portal wherein after a successful captive authentication, the guest/s will be redirected to a specific URL you have indicated such as a Facebook business page or company website.
Kindly read pages 232-243 of the WC7600v2 / WC9500 user manual here about setting up a Captive Portal.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Retired_Member,
DaneA
- Retired_Member
Sadly the 7600/9500 are outside the budget for the small business that want it. Will search for another solution
