Decenenti
Feb 17, 2017Aspirant
Can't Factory Reset WC7520
I m trying to factory reset a ProSafe WC7520 controller so we can get access (unknown username and password) however am having no luck.
I have tried the instructions here: http://kb.netgear.com/6668/Factory-reset-of-Wireless-Controllers of holding down the reset button for 5 seconds when powering on (and have held for much longer). However I still cannot access or ping the default IP when it boots, and with a console cable the default username and password (admin/password) are not accepted.
Is there anything else I can try to ge access to the unit?
Hi,
Before raising a support case, Can you press and hold the reset button for more than 10seconds, and until the power LED starts blinkiing. On the consoloe you should be able to see the following message
"FACTORY DEFAULT APP: Reset to default requested, system will be restarted shortly !"
- DaneANETGEAR Employee Retired
Hi Decenenti,
Welcome to the community! :)
Kindly answer the questions below:
a. Have you disconnected the WC7520 from the existing network then perform a factory reset on it?
b. Have you tried another PC/laptop to connect it directly to the WC7520 then try to ping its default IP address?
c. What is the behavior of the LED lights on the WC7520?
DaneA
NETGEAR Community Team
- DecenentiAspirant
Hi DaneA, thanks for getting back to me, please see below:
Yes, at first the device was only connected to a PC with a console cable. I have since connected it to a PC through a space switch to try and get browser connectivity, however it is not connected to the network.
I have tried one laptop and one PC connected to the device and neither can get a ping response from the default IP address.
When I power on the device with the Factory Reset button held down, the Power and Test LEDs are both on. The output of the console port is:
Executing bootcmd in 5 seconds - enter ctrl+c to abort
However nothing happens unless I release the Facory Reset button.
When I release the Factory Reset button it runs through the boot process, and both LEDs stay on through some of this, until just the Power button remains lit. I can then get to the login prompt however it does not accept the default admin/password. Also I cannot ping the device on either the previous, or default IP address.
It seems that the WC7520 is faulty. With regard to this, I suggest you to open an online case or chat case with NETGEAR Support at anytime. Let them know about the status of the WC7520 wireless controller. Be ready to submit a .doc or .pdf copy of the Proof of Purchase or Sales Invoice of the WC7520 for warranty verification. If ever the hardware warranty is still valid then an online replacement will follow.
DaneA
- Nov 23, 2018Retired_Member
