  • > I tried to download the last Firmware oft the Wifi-router WAC104 from
    > this page, [...]
       How did you get to that page?
    > [...] but i didn't find any download button
       That may be normal for a KnowledgeBase atricle.  On the right side, I
    saw a useful link under "This article applies to:".  Generally, I'd
    suggest: Visit http://netgear.com/support , put in your model number,
    and look for Downloads.
    • Paderborner's avatar
      Paderborner
      Hi antinode,
      Thanks for your quick answer!
      i found the site via the site search on top of the site.
      So, i am gonna wait for the download-link on the page for the upgrade.
      Thank you!
      • antinode's avatar
        antinode
        Guru
           The built-in search on Netgear's site is sub-ideal.
           It's your decision, but if you're waiting for a change on the
        KnowledgeBase article page, then you may be in for a long wait.  It
        already has a link to the product support page:
              https://www.netgear.com/support/product/WAC104
        which offers links to the firmware kits.  Or:
        > [...] Visit http://netgear.com/support , put in your model number,
        which leads to the same place.
ProSupport for Business
