dennis48755
Jun 15, 2017Aspirant
Guest Wi-Fi
Hi, I would like to set up a seperate Guest Wi-Fi access to the internet only. The configuration diagram posted by DaneA here shows what I would like to do, substituting - FVS336 for the Firewall Ro...
- Jun 21, 2017
Hi dennis48755,
Basically if you wanted to create multiple VLANs to passthrough on a single port or Trunk. For VLAN aware devices such as switch, access point, router, VOIP Phone, etc.), the port should be set to T or Tagged under specific VLAN membership and for non-VLAN aware devices(like printers, hub, PC, etc.), the port should be set to U or Untagged under specified VLAN membership then set the PVID to specific VLAN.
e.g.
JGS516PE VLAN 802.1Q Advanced VLAN Membership...
VLAN 1 All ports - U (Default)
VLAN 250:
- Port 1 - T (WNDAP360)
- Port 2 - T (WAC720)- If you wanted a PC to be a member of VLAN 250, You may set the port to U, then assign PVID 250.
- Port 16 - T (Firewall)Regards,
JohnC_V
Jun 21, 2017NETGEAR Employee Retired
Hi dennis48755,
e.g.
VLAN 250:
dennis48755
Jun 23, 2017Aspirant
JohncarloV,
Thank you for your reply and suggestions.
It appears the settings you suggested are working just as I was hoping.
In my testing when connected to my "Dennis" Wi-Fi, ipconfig shows I am connected to my primary network (192.168.90.xx) and I have access to my network devices. When connected to "Guest", ipconfig shows connected to 192.168.100.xx and no network decies appear.
Thanks again for you help.
Dennis
