andylee6179
Dec 19, 2024Initiate
Help. After Zero Day setup, Web Interface no longer loads
Hello All, I just purchased this WAP and only wanted to use the local set up options, not Insight as we don't want that option as well as avoid the subscription. Noticed that when I try to conn...
- Dec 19, 2024
Nevermind. Found the solution. Its a Mac settings issues related to Privacy and Security:
MAC OS System Settings > Privacy and Security. Then scroll to find Local Network. Enable for Google Chrome.
andylee6179
RennaD
Dec 19, 2024NETGEAR Moderator
Hi andylee6179,
Welcome to the NETGEAR Community! 🙂
Glad to hear that you were able to figure out the setting on the MAC OS and proceed with the AP setup. Since your issue is resolved, I encourage you to mark the appropriate post as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
