mikey6283
Dec 26, 2023Aspirant
Help in login into WAX610 after reset
Hope someone can help as a noobie with Access Point although it has been working for 7-8 months fine. I upgraded to the latest firmware 10.7.1. The AP just would not send out a signal to IOT or to ...
schumaku
Dec 26, 2023Guru - Experienced User
Default username and password (admin / password) as shown in the fine Insight Managed WiFi 6 AX1800 Dual Band Access Point Model WAX610 Installation Guide still apply. The only exception applies if you have added the WAX610 to Insight - open the App, login accordingly, then head to to Locations -> Location Configuration - here you can define the local Device Admin Password. Give some moment to deploy before attempting a local login in case you have changed the admin password.
