Glenikins
Jan 03, 2018Aspirant
How to access web interface on WAG102 with a modern browser
I am unable to open the web interface on our WAG102 access point. I've tried Microsoft Edge, IE11, Chrome and FIrefox. All report similar errors, associated with SSL/TLS. Is there any way that I can ...
- Feb 07, 2019
I needed to reset some things on several WAG102s we have. The answer was to download and install Virtualbox (you could use another if you wanted) then go to
https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
and download a virtual machine with IE8.
It was fairly easy to get running and easily connects to the WAG102 interface.
schumaku
Jul 12, 2018Guru - Experienced User
Almost any - except if "robust" does translate to a heavy duty metal enclosure. The WAC505 is very affordable, 2x2 802.11ac Wave II, for example, without breaking the bank - it starts from about 75 USD for PoE or 85 USD with an external power supply - pricing varies depending on your market/region.
Still - considering it's secure enough otherwise (probably no WPA2 AES, vulnerable e.g. to KRACK, ...) - can't your legacy device not be accessed and managed by http anymore?
Oharvey
Jul 12, 2018Aspirant
Yes - I did mean t
Robust by the fact they are in metal enclosures.
I have been using these for 10 years + / can be picked up for £15 . Frustrates now by inability to access by http / disable Https.
I live/work on a large farm so no real danger of security issues.
I have recently deployed down ubiquiti units but the range is pretty poor compared with these old units
Thanks again
Thanks again
