Kabouelneel
Jan 23, 2017Aspirant
How to Convert WNDAP360 to standalone
I've bought WNDAP360 access point, and after openning the management page i found it's not standalone mode with firmware version 2.3.1.5_1400 which i think a controller firmware. My q is how do i...
- Jan 23, 2017
HI Kabouelneel,
If you have a controller(as per the image in AP, it is WC7520 controller model ) try to upgarde it to latest image by downloading a Firmware for the cotroller here:
https://www.netgear.com/support/product/WC7520?cid=wmt_netgear_organic#download
Or for making the AP to standalone you have to follow the steps mentioned(upgrade path) in the below URL, as from "2.3.1.5_1400" to direct 3.5 version is not supported due to some limitations.
http://kb.netgear.com/31404/WNDAP360-Firmware-Version-3-5-20-0?cid=wmt_netgear_organic
Upgrade the AP with V2.1.11 standalone FW and then do a restore factory default settings. then follow trhe below sequence.
Firmware upgrade sequence for WNDAP360 from 2.x:
V2.1.11 -> V2.1.12 -> V3.5.20.0 - Correct sequence.After loading the V3.5.20.0, open the AP GUI and Apply "NO" for "Buisiness Central Enabled" settings to use the Accesspoint in standalone mode.
SureshV
Jan 23, 2017NETGEAR Expert
HI Kabouelneel,
- KabouelneelJan 24, 2017Aspirant
Thank you so mush for your reply, and I'll test the solution today. I'll get back to you if any issues.
