Kabouelneel's avatar
Kabouelneel
How to Convert WNDAP360 to standalone
I've bought WNDAP360 access point, and after openning the management page i found it's not standalone mode with firmware version 2.3.1.5_1400 which i think a controller firmware.   My q is how do i...
  • SureshV's avatar
    Jan 23, 2017
    HI Kabouelneel,
    If you have a controller(as per the image in AP, it is WC7520 controller model ) try to upgarde it to latest image by downloading a Firmware for the cotroller here:
    https://www.netgear.com/support/product/WC7520?cid=wmt_netgear_organic#download
    Or for making the AP to standalone you have to follow the steps mentioned(upgrade path) in the below URL, as from  "2.3.1.5_1400" to direct 3.5 version is not supported due to some limitations.
    http://kb.netgear.com/31404/WNDAP360-Firmware-Version-3-5-20-0?cid=wmt_netgear_organic
    Upgrade the AP with V2.1.11 standalone FW and then do a restore factory default settings. then follow trhe below sequence.
     Firmware upgrade sequence for WNDAP360 from 2.x:
      V2.1.11 -> V2.1.12 -> V3.5.20.0 - Correct sequence.
    After loading the V3.5.20.0, open the AP GUI and Apply "NO" for "Buisiness Central Enabled" settings to use the Accesspoint in standalone mode.
ProSupport for Business
