nanorobocop
May 07, 2020Tutor
How to disable SSO login?
Hi here! I'm happy owner of Netgear WAC124 access point. Firmware Version V1.0.4.4 When setup first time I've created netgear account and registered the product. But on next logins it always re...
dehart007
Sep 09, 2020Initiate
Yeap - definately need an option to login to the router locally without going out to internet for SSO. It's my dam router that I bought and I should not be holden to a cloud account to login locally to my device. YO NETGEAR, are your hearing us!!! FIX IT!!!!! If I knew this I would of purchased the other router I was looking at from ASUS that DOES ALLOW YOU TO LOGIN LOCALLY!!!!!!
