nanorobocop
May 07, 2020Tutor
How to disable SSO login?
Hi here! I'm happy owner of Netgear WAC124 access point. Firmware Version V1.0.4.4 When setup first time I've created netgear account and registered the product. But on next logins it always re...
Jakobud
Oct 05, 2021Initiate
For anyone still looking into this, I have found a partial solution.
The router login page is sso.html
There are 3 possible login forms:
1. The local login (what you want)
2. The first time login (when you first power on the router)
3. The Internet SSO Netgear login (yuck)
All 3 of these forms are actually on the login page, sso.html, the others are simply hidden.
The way the page determines which login form is shown, is a page-level JavaScript variable called "hasInternet". The value is set internally by the firmware and is baked into the page source. The value changes constantly and is some sort of time/date format like "418:33:34". I'm not sure what this time is indicating.
Anyways, if the "hasInternet" has a value of "00:00:00" that means the router has internally determined you don't have internet access. In this case, the page simply uses JavaScript to hide the SSO login form and display the Local Login form.
I'm not sure if there is a way to trick out the AP to change that "hasInternet" value. Maybe with firmware hacking. I dunno.
BUT you can use simple JavaScript on the page to hide/show the login login form and ignore the SSO login form.
SSO login form HTML div element ID: "box_internet_everlogon"
Local login form HTML div element ID: "box_local_login"
So if you open up the browser dev tools and goto the JavaScript console you can use the following Javascript
(function(){ document.getElementById('box_local_login').style.display='block'; document.getElementById('box_internet_everlogon').style.display='none'; })()
Just copy and paste that in and run it.
TADA: Now the SSO login is gone and the Local login is accessible and ready to accept input.
So how can we make this a little more accessible? A pain to open up the console and copy/paste this thing every time you login right? How about a browser Bookmarklet?
In your browser create a new Bookmark. Give it any name, like "Netgear Local Login" or whatever you want. For the URL paste in the following Javascript:
javascript:(function(){ document.getElementById('box_local_login').style.display='block'; document.getElementById('box_internet_everlogon').style.display='none'; })();
For some reason Netgears Message Board is replacing the "colon" in the above code with the HTML colon entity code ":". Anyways it should look like this at the start:
Now, whenever you get to your Netgear AP SSO login page, click on their bookmark. The JavaScript in the bookmark will execute and you will now magically have your local login instead of the stupid Netgear SSO login.
There may be other ways of automating this, such as a Chrome/Firefox extension that automatically can execute custom JavaScript whenever you access certain URLs. Or something to automatically open the Bookmarklet when you get to this URL. I haven't really looked deeper into it beyond this.
This isn't a perfect solution, but I hope it helps everyone. Netgear should really not require SSO logins for local network devices. Really really dumb idea.
DaveLister
Oct 15, 2021Tutor
Jakobud wrote:For anyone still looking into this, I have found a partial solution.
(function(){ document.getElementById('box_local_login').style.display='block'; document.getElementById('box_internet_everlogon').style.display='none'; })()Just copy and paste that in and run it.
javascript:(function(){ document.getElementById('box_local_login').style.display='block'; document.getElementById('box_internet_everlogon').style.display='none'; })();For some reason Netgears Message Board is replacing the "colon" in the above code with the HTML colon entity code ":". Anyways it should look like this at the start:
Sweet thanks!!!
- AlainCoJan 04, 2022Initiate
This trick allows to enter the login password, but this ends in smetime a forbidden, or just the same redirect to sso page...
thanks anyway but it seems they disabled the hack
