nanorobocop
May 07, 2020Tutor
How to disable SSO login?
Hi here! I'm happy owner of Netgear WAC124 access point. Firmware Version V1.0.4.4 When setup first time I've created netgear account and registered the product. But on next logins it always re...
kas1kas
Feb 09, 2022Initiate
Entering the MAC address of the Netgear router is absolutely the easiest and best way of getting rid of the ridiculous Netgear policy.
Only thing is that the Netgear router must be behind another router that accesses the internet.
If the Netgear is your only modem and router you can use the scripting work around.
So, get a good product to connect to the internet and use this Netgear crap for internal purposes only.
