rovo
Jun 29, 2021Tutor
Insight back to Local WAC510
Hello, I'm interested to try out the Insight Managed, but I'm unsure how I will be able to switch back to Local Managed if I don't want to stay with Insight Managed? Is there an option in the Insigh...
- Jun 29, 2021
To keep it simple, take a config backup, convert the WAX510 to the Insight management (makes mainly sense if you have multiple WAC/WAX and at least one cloud managed switch). If you remove the devices from Insight, you can always recover from the config backup(s).
schumaku
Jun 29, 2021Guru - Experienced User
rovo
Jun 29, 2021Tutor
Appreciate the advice!
I have only 2 WAC510s and no cloud managed switch. Maybe best I leave it alone then.
Thank you.
- schumakuJun 30, 2021Guru - Experienced User
The roaming behaviour for the two WAC could be enhanced in my understanding - in standalone management, the roaming capabilities are limited.
