yodamin
Apr 11, 2025Aspirant
Insight subscription ended-how do I logon to my router?
OK Again--my son just walk into my office, I told him about this and he said, "I forgot to tell you I changed the IP a while ago. Sigh. Apologies to all. The GOOD thing about this post is that it ...
- Apr 11, 2025
Thanks but I did not need to do that.
AS my edited question reveals , I did get logged onto the device and I simply changed the management mode to local instead of Insight or Cloud based.
Apr 11, 2025Guru - Experienced User
Reset and setup from scratch using a wired PC and web browser.
Refer to any quick installation guides or user manuals for the product model your referring too.
yodamin
