c0wkim0n
Sep 27, 2018Aspirant
iphone connect to WAC720 captive portal ON & web re-direct to my website, twitter/FB will auto load
Hi everybody, I need urgent help on this matter, I bought the Netegear WAC720 AP router cause I need captive portal and web re-direction, and so I got it last week, configure it to enable captive por...
- Sep 27, 2018
Welcome to the Netgear Communiity!
c0wkim0n wrote:
my netgear wac720 is brand new router with firmware update to 3.7.10.0
Don't know if it's of any help - current firmware for the WAC720/WAC730 is 3.9.0.3 as per the Netgear Support WAC720 Downloads.
schumaku
Sep 27, 2018Guru - Experienced User
RaghuHR
Sep 28, 2018NETGEAR Expert
Hi c0wkim0n
I sent you PM last night asking you to upgrade to latest firmware and check? Could you please share your feedback on the latest firmware?
If you are still seeing the issue then please share the your AP configuration and send me via PM? We may need detailed logs from Monitoring page too.
Did you checked behaviour by opening a web browser instead of auto pop up?
Looking forward to hear from you soon.
Thanks,
Raghu
