kortina
Mar 28, 2023Aspirant
Laptop not switching to closer WAX610 access point automatically
I have 2 WAX610 Access Points, one on my 1st floor, one on my 2nd floor. I opened my laptop on the first floor, then went upstairs to the 2nd floor to the same room (about 6ft away) from the 2nd ...
kortina
NB: I have both APs broadcasting the same SSID and both APs are hard wired into an ethernet connection as the WAN source.
Under Advance Mesh Configuration I have set "Disable Mesh," because I do NOT want one AP using another AP as a WAN source over wifi
schumaku
Mar 28, 2023Guru - Experienced User
This is correct, because I understand both WAX610 are connected to the same wired LAN, and don't need one to serve in a wireless Mesh config therefore.
