lschwenk
Mar 29, 2025Aspirant
Migrate home wifi to WBE710s
Installing two WBE710s and a WAX610Y outside; all powered by MS510TXUP (connected to a SonicWall TZ570). I'm currently using a Deco XE75 (three inside and their external unit outside), 70+ device...
- Mar 30, 2025
lschwenk wrote:
But the more I think about it and I do have a few older devices, why not, it doesn't affect anything. So now I'm looking at:
SSID1 (current) WPA2
SSID2 (new) WPA3
I'll just leave 90% of my items on SSID1 as they are very low bandwidth (smoke detectors, sonos, smart outlets...) and re configuring those will be a total pain, all day effort.
And I'll move the new tech, iPhones, iPads, laptops, TVs... (high bandwidth, easy to change) and such to SSID2 so they can fully use any of three bands and automatically adjust.
Correct approach, yes!
lschwenk wrote:
A final option, which in my particular case, is to turn off security and only use access control, MAC address filtering. I know everyone is rolling their eyes, but in my rural house setting... Basically I'll walk my property. If I set it up right and I loose connection at the edge of my property then I'm good. If someone where to come on, they'd still have to figure out what I'm doing, search a current MAC address and then spoof it. Not the best idea, but it is a potential valid solution in my situation.
Negative, you can't configure an SSID without any or no security on the 6 GHz band. As mentioned before, WPA3 is mandatory on the 6 GHz band.
When you look around, you will find to many posts in the community where network operators struggling on the fancy "Private MAC" or "Random MAC" - very useful when operating on public WiFi or other unknown networks, but a pain in the back on your own managed network.
schumaku
Mar 29, 2025Guru - Experienced User
....my plan is to turn off the Deco, reboot the SonicWall to flush all DHCP leases, and then change the Netgear SSID to my original one. Everything should magically pop right up??? Hey, I can hope....its sounds logical.
Sounds like like a good plan in general, some considerations for the planning:
The crux with both 6 GHz -and- WPA3 is that 6 GHz band does have the WPA3 mandatory, no way to continue operating WPA2. Guess that potentially caused some issues for your WiFi calling - a tech running trouble-free nowadays, as soon as you have reliable WiFi coverage.
Many of not most wireless devices require to "forget" the previously stored WPA2-only config, and re-adding each for WPA3 (or WPA2/WPA3-mixed mode). Once you know for sure all your wireless devices can be migrated to WPA3, there are no more show-stoppers to go forward. Worst case, define an additional SSID for the non-WPA3 capable devices for the time being.
Good luck, and have fun with your new network, very promising environment!
-Kurt.
