CHlbrands
Jan 02, 2024Aspirant
Mobile apps dont get connection
Hi, I have a question regarding the WAX630. I am getting complaints of mobile devices (smartphones) that does not load apps. The apps are of a wide variety of companies like financial services, the...
michaelkenward
Jan 02, 2024Guru - Experienced User
While many questions about standard routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
You could also tell people what else is on the network, especially the nodem/gateway/ONT that sits between WAX630 and the Internet.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
CHlbrands
Thanks for the response michaelkenward .
I shall have a look there as well. The ont ant modem/router is from the isp and i can not say something about it because you need to use them. The modem/router combo is Sagemcom F5359 with KPN experiabox firmware on it. The ONT is not visible so for now it is unknown.
But i shall have a look in the different places of the forum and have a look in the documentation again. And sorry that i did not mention it before.
Kind regards,
Christian
