mhndsh
Mar 15, 2018Aspirant
Mobile devices slow on WG103
Hi, Comparing download speed between any mobile device in my network and the download speed from any laptop, i have: * my ADSL is 8Mbps * i do the download test for the same file from the same url...
- Mar 20, 2018
Thanks..
I have 10 APs in the area, all were on channel 1 (i don't know why they don't change the channel to another free one)..
I but them on channels 1,6,11 (and will put later on 1,5,9,13) and it's better now..
I think the problem was overlapping...
JohnC_V
Mar 19, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- mhndshMar 20, 2018Aspirant
Thanks..
- JohnC_VMar 21, 2018NETGEAR Employee Retired
That's great! If you do have multiple APs and it is not being handled by a wireless controller, it is not advisable to use the same channel as it will only cause radio interference.
