dfunkt
Apr 06, 2023Aspirant
MS108EUP multi gig switch cannot update firmware from factory 1.0.0.7 to 1.0.1.6
Help! I am trying to update my MS108EUP from the website console after downloading the image from the Netgear website. Factory firmware - 1.0.0.7 The process seems to start and the switch reboo...
schumaku
Apr 07, 2023Guru - Experienced User
Have unpacked the ZIP archive first? There are two files in the archive:
07.04.2023 11:07 9’141’884 MS108EUP-V1.0.1.6-runtime.image
07.04.2023 11:07 740 MS108EUP_V1.0.1.6_Release_Notes.html
2 Files, 9’142’624 Bytes
- dfunktApr 07, 2023Aspirant
That would be a good thought!! I downloaded it on my Apple Mac and it doesn't seem to be zipped in any way. Could that be my problem? Should it be downloaded on a Windows computer and unzipped there?
I downloaded it on my Windows computer and unzipped it. Still same issue. So this thing cannot update at all. I have already taken it out of Insight as it was added when I used the Netgear Switch Discovery Tool and I saw others suggesting to remove from this Insight discovery tool. So still no go.
- schumakuApr 07, 2023Guru - Experienced User
Either way, MS108EUP_V1.0.1.6.zip -is- a zip archive indeed, containing the two files as shown before.
The extracted and stored file to be selected for upload is this one:
Amazing what overly smart desktop environments make out of file names.
The NSDT does not have any data storage, neither do these switches connect to Insight.
Yup, that is the correct filename that I tried to upload. still no update. So maybe this unit does not accept updates?
