dfunkt
Apr 06, 2023Aspirant
MS108EUP multi gig switch cannot update firmware from factory 1.0.0.7 to 1.0.1.6
Help! I am trying to update my MS108EUP from the website console after downloading the image from the Netgear website. Factory firmware - 1.0.0.7 The process seems to start and the switch reboo...
schumaku
Apr 07, 2023Guru - Experienced User
Have unpacked the ZIP archive first? There are two files in the archive:
07.04.2023 11:07 9’141’884 MS108EUP-V1.0.1.6-runtime.image
07.04.2023 11:07 740 MS108EUP_V1.0.1.6_Release_Notes.html
2 Files, 9’142’624 Bytes
dfunkt
Apr 07, 2023Aspirant
I downloaded it on my Windows computer and unzipped it. Still same issue. So this thing cannot update at all. I have already taken it out of Insight as it was added when I used the Netgear Switch Discovery Tool and I saw others suggesting to remove from this Insight discovery tool. So still no go.
- schumakuApr 07, 2023Guru - Experienced User
Either way, MS108EUP_V1.0.1.6.zip -is- a zip archive indeed, containing the two files as shown before.
The extracted and stored file to be selected for upload is this one:
Amazing what overly smart desktop environments make out of file names.
The NSDT does not have any data storage, neither do these switches connect to Insight.
- dfunktApr 07, 2023Aspirant
Yup, that is the correct filename that I tried to upload. still no update. So maybe this unit does not accept updates?
- schumakuApr 08, 2023Guru - Experienced User
Looks perfectly correct, indeed. Still unclear if some Internet security wonder does block the file. no crappy Internet security software (except of the Microsoft Windows standard stuff) in place?
Restart the switch, just in case, check the IP address in case it's using DHCP, and retry.
Not that I expect a big difference: Dropping the browser cache does sometimes help, too.
