jamesstoner
Jul 25, 2023Star
Multiple APs broadcasting the same SSID twice
Hi, Support. I have a an issue where I have two separate APs (A WAX214 and a WAX214v2) broadcasting the same SSID but my devices are seeing the SSID twice. The channels are different on both APs....
schumaku
Jul 25, 2023Guru - Experienced User
Hello James,
Ensure not just the SSID are the same on both APs, and also the security settings and the PSK.
-Kurt
- jamesstonerJul 25, 2023Star
Hi, Kurt.
I can confirm all security settings are the same on both APs.
Please see images below:
AP 214AP214v2
The passphrase's are identical but not shown due to obvious reasons.
Is there anything else I have missed?
Thank you,
James Stoner
- schumakuJul 25, 2023Guru - Experienced User
Operating two WAX214 (in two variants, WAX214, on v2.1.1.3 and WAX214v2, on v1.0.2.3) with one same SSID and similar mixed WPA2 and WPA3 PSKs for other testing purposes. Have not observed any double AP announcements, neither on various decent Android nor on iOS mobiles, nor on Windows, nor on Mac OS clients.
Curious, what mobile device model and OS version we're facing in your test case.
Hi,
It seems this is not an issue on my IOS / Android devices, but is an issue on my Windows laptop.Thanks for your assistance. I will look into this separately and provide a resolution if I find one, it possibly just needs a reboot (haha).
Thank you,
James Stoner
