MikhaelS
May 30, 2021Tutor
My PS4 will connect WIFI to my WAC510 router and the internet, but can't use PSN.
Please Help
Hi MikhaelS
Thanks for confirming your PlayStation is working. Please mark this thread as accepted solution so that other user will get benefited .
Raghu
- MikhaelSTutor
Done
- RaghuHRNETGEAR Expert
Hi MikhaelS
Thanks for sharing the logs.
Could you please check the following?
1. Disable URL filtering and try to connect to the Play station network.
2. From the attached images for Play station network to work properly we need to enable the following ports on the router side. Check whether the following ports are enabled on your main router.
TCP : 80, 443, 3478, 3479, 3480
UDP : 3478, 3479
