madpeanut
Mar 16, 2016Aspirant
Need a recommendation
Hello, I need a recommendation for a router. I saw the WAC730, will that allow me to take my connection from fiOS and add additionally access points throughout the house the extend my network? ...
- Mar 16, 2016
Hello madpeanut,
Welcome to the community!
The WAC730 is not a router but an access point, it does not have its own DHCP server and NAT. Access points needs to be connected to the router unless you are using bridging/repeating mode. The more times the signal is repeated the bandwidth speed is being cut in half (or almost). There is a cheaper version, the WAC720 which is also a good alternative. You can take advantage of the "ensemble" feature of these models which allows you to use the same SSID and creating a roaming network. Please click here on how to configure ensemble.
Let us know if you have more questions.
Thanks,
madpeanut
Also WAP's, is there a more cost effective version I can deploy at the furthest reaches so it will be slower but still have access?
- JohnRoMar 16, 2016NETGEAR Employee Retired
Hello madpeanut,
Thanks,
- madpeanutMar 16, 2016Aspirant
Ok, so would it be possible to use my current netgear consumer router with the waps by wire and turning off the wireless on the router?
- mdgm-ntgrMar 16, 2016NETGEAR Employee Retired
Yes
These are designed for business so if you are not using a POE (Power over Ethernet) switch you would need to purchase the optional power supply for each WAP. So you might wish to put a POE switch between the router and the WAPs.
