madpeanut's avatar
madpeanut
Need a recommendation
Hello,   I need a recommendation for a router.  I saw the WAC730, will that allow me to take my connection from fiOS and add additionally access points throughout the house the extend my network?  ...
  • JohnRo's avatar
    JohnRo
    Mar 16, 2016
    Hello madpeanut,
    Welcome to the community!
    The WAC730 is not a router but an access point, it does not have its own DHCP server and NAT. Access points needs to be connected to the router unless you are using bridging/repeating mode. The more times the signal is repeated the bandwidth speed is being cut in half (or almost). There is a cheaper version, the WAC720 which is also a good alternative. You can take advantage of the "ensemble" feature of these models which allows you to use the same SSID and creating a roaming network. Please click here on how to configure ensemble
    Let us know if you have more questions.
    Thanks,
ProSupport for Business
