ewrankend
Oct 09, 2023Follower
Need equipment recommendation
I was running Luxul APs and a Luxul router. I had 3 failed APs in 2 years and wasn’t really happy with them anymore so I switched to Insight WAX615 APs (I have 4) and a GS305EPP switch. I didn’t nee...
michaelkenward
Oct 10, 2023Guru - Experienced User
ewrankend wrote:
I also don’t need/want WiFi built into the router.
All Netgear routers come with wifi.
What is the modem/ONT/gateway that delivers the Internet to your network?
I am looking to spend about $200ish.What do you recommend?
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
For $200, you might want to consider second hand or refurbished hardware.
schumaku
While a little bit over the 200 USD budget, and considering we're in the Netgear Business section here, I have to disagree. Netgear had released the PR60X these weeks. It's readily available in many markets, does not come with built-in Wi-fi as mostly useless in a rack installation anyway. And yes, it's Insight manageable, too.
