VIRTUALWORLD
Jun 24, 2025Aspirant
Netgear Access Point for Handling RSSI and CSI
I am trying to develop a system using some Access Points that support the following functions.
Please let me know if there is a Netgear Access Point that supports the following functions.
It would be appreciated to let me know.
- Ability to collect smartphone MAC address, RSSI (Received Signal Strength Indicator) information, etc.
- Ability to collect CSI (Channel State Information) information and send it to a PC
(In this case, Access Point can be set as a receiver or sender)
- Network analysis must be possible by installing OpenWRT.
- Ability to send MAC address, RSSI, CSI information data to a PC
Many Thanks.
so you've already narrowed your list by "must be possible by installing openwrt".
Check their supported device list and pick something from that.
- VIRTUALWORLDAspirant
I appreciate your kind answer so much. Many Thanks.
