VIRTUALWORLD
Jun 24, 2025Aspirant
Netgear Access Point for Handling RSSI and CSI
I am trying to develop a system using some Access Points that support the following functions.
Please let me know if there is a Netgear Access Point that supports the following functions.
It would be appreciated to let me know.
- Ability to collect smartphone MAC address, RSSI (Received Signal Strength Indicator) information, etc.
- Ability to collect CSI (Channel State Information) information and send it to a PC
(In this case, Access Point can be set as a receiver or sender)
- Network analysis must be possible by installing OpenWRT.
- Ability to send MAC address, RSSI, CSI information data to a PC
Many Thanks.
- VIRTUALWORLDAspirant
I appreciate your kind answer so much. Many Thanks.
so you've already narrowed your list by "must be possible by installing openwrt".
Check their supported device list and pick something from that.
