baofengx
Jan 10, 2024Aspirant
netgear essentials wifi6 AX1800 Access Point WAX214v2 IS very slow
Hello everyone,
We use two AP(netgear essentials wifi6 AX1800 Access Point WAX214v2) for Wifi, but the wifi is very slow.
I have tested the LAN speed, when use network cable is about 800Mbit, but when use the WIFI connection the speed is only about 100Mbit.
Why is this? I have no idea.
And, the WiFi also often disconnects and reconnects.
How do i implove it?
Thank you!
- baofengxAspirant
The test result is:
Ni hao baofengx
Double check your Wi-Fi clients are able to handle higher speeds.
Ensure the WAX214v2 5 GHz Wireless is configured for fixed 80 MHz bandwidth, or at use the dynamic 20/40/80 MHz Channel HT Mode.
Lot of concurrent Wi-Fi systems on air at or near to the same location? Sounds like a typical interference issue.
Run some audit on what is ongoing on air, and try to change bot the 2.4 GHz and 5 GHz channel configuration accordingly.
What wireless client, client OS and driver version are you using for your test?
