zwann
Oct 10, 2017Aspirant
Netgear Insight
Hi all, I have changed the mail address for our netgear insight account and we cannot connect anymore. Here's the error : "Some error occured while updating user,Please try again" I can connec...
JohnC_V
Oct 11, 2017NETGEAR Employee Retired
Hi zwann,
Welcome to our community!
As per checking on your profile. I was able to see that you do have multiple WACs on your account. So I think your account was still intact. But the question is, did you merged your profiles before changing your email? I believe we do have a single sign on for this apps.
- zwannOct 13, 2017Aspirant
Hello,
Probably not.
Can you help me figure this out ? I need to be able to use the Insight android app to configure those APs.
TIA !
Stephen
- JohnC_VOct 16, 2017NETGEAR Employee Retired
As far as I know that all email accounts on Netgear is single-sign on. One registration can login to all Netgear supported websites.
- zwannOct 17, 2017Aspirant
Could you tell me how I can connect with my credentials to the android app. I'm still receiving the error : "Some error occured while updating user,Please try again"
For the record, I can connect to the my.netgear.com with the same credentials without any problem.
Thanks for your help.
Stephen
- Apr 02, 2019Retired_Member
