TheGuru47
May 26, 2025Aspirant
NETGEAR WAX610 Dual-Band WiFi 6 Access Point
Hi. I want to create a local network that allows my devices to communicate directly with each other without having an internet connection. This way, I can use a master/slave app during band rehearsa...
May 26, 2025Guru - Experienced User
There really shouldn't be anything to change. It should still function without an internet connection
TheGuru47
When I disconnect the CAT5 cable, I lose connectivity.
- schumakuMay 27, 2025Guru - Experienced User
That's the way it is - a Wireless Access Point is a bridge connecting one or multiple SSIDs with an Ethernet in the first iteration. But then, I'm comnvinced a strandalone AP will still allow the L2 conneciton between the wireless clients, unless this was disabled - even without an Ethernet or even an Internet conneciton
- TheGuru47May 27, 2025Aspirant
Exactly what would have to be enabled?
