TheGuru47
May 26, 2025Aspirant
NETGEAR WAX610 Dual-Band WiFi 6 Access Point
Hi. I want to create a local network that allows my devices to communicate directly with each other without having an internet connection. This way, I can use a master/slave app during band rehearsa...
May 27, 2025Guru - Experienced User
Does it actually work without internet? Is this app syncing back to a central server in the cloud? Or is it locally hosted? You've already checked it with data enabled on the phone. Easy check is to hotspot the phone but turn off its cellular service. IF it works without data enabled, it should be locally hosted versus syncing back to the cloud
